GregValiant 1,489
As Carla said, the best option is to set the initial layer height. You can also push the "Material / Initial Layer Flow" up to 110% or 120% BUT that would mean more plastic in the way for the subsequent layers and you would still have over-extrusion symptoms unless you back the flow off to 95% for layers 2 to 5 or so. I've gotten very consistent at leveling the bed and I run Initial Layer Height at .20 and Initial Layer Flow at 105%.
Those layers just above layer#1 generally get covered right up by infill or another layer. I like to concentrate on the first layer because it is so important to a good print. A little over-extrusion on inside layers is a good thing. Under-extrusion can lead to weakened parts.
Carla_Birch 116
Hi @PharmDDan
You don't need to adjust your print bed height after the first layer, In Cura under the Quality settings, adjust the setting "Initial Layer Height" you have it matching the normal layer height and its better to have it set bigger so it pushes down to the print bed more for the first layer. A good setting for this would be 0.20 mm
Edited by Carla_BirchLink to post
