Ultimaker 2 Extended+ SD Card
Posted · Ultimaker 2 Extended+ SD Card
Today I unboxed my new Ultimaker 2 Extended+ printer.  Set it up and went to print an example piece from the factory SD card.  But the SD card is blank - display says "No files found!"
Anyone know where I can get test print files?
Thanks
    Hi redwards64,
    Welcome in here and congratulation with your brand new UM2E+!
    I've an UM2E that's upgraded later to a plus version, however, I do not have the files that's comes with a new printer.
    I'm just a member like you in here, -for you to know.
    There might be someone in here that can share those files.
    But I'm sure @SandervG can help you with this issue.
    Thanks
    Torgeir
        • 24 replies
