Has anyone printed in ABS, and if so, what are your settings? Wanted to print some prints in ABS (PLA got boring after a while).
Print temp is about 30-40C higher than PLA, packing density is 0.85, as jen mentioned, your e steps are probably a bit lower (ABS is softer than PLA).
if you have a heated bed, you need about 110-115C surface temp, and you can print on plain glass (112-120C)
other than that, it's pretty much the same, minus the horrible oozing of liquid PLA.
jenschr 6
Prints fine using just the same settings as PLA with the exception of setting Packing density to 0.85 :-)
J
