I had to look that one up. "Support Horizontal Expansion" was defaulted to 0mm.
That setting that you are looking at is only to make "use towers" setting visible in the custom settings menu in cura. It's not telling you that the setting is off or on.
If you click that box then you will be able to see it when adjusting the print settings and be able to turn it off there.
This helps you set up the printer settings menu so it only shows settings that you want to adjust. Which can be very helpful.
You can also search these hidden settings (ones you haven't ticked in setting visibility) in the search bar at the top of the settings list.
Wow. MAJOR brain fart on my part and I should have known better. I made the setting visible and it was indeed checked. After UN-checking and re-slicing, I get exactly what I was after.
To make matters worse, I sliced this same piece for printing on a different printer, and the towers were not present. At that point I was fairly certain it was a slicer setting, but a the time I did not have time to investigate and it slipped my mind.
So thank you very much for resolving my issue.
Thanks for keep us informed. 👍
Enigma_M4 120
Hi Xeddog,
try reducing "Support Horizontal Expansion" to 1mm or even 0mm. This should result in support only inside the gaps (cable tie slots?) and screw holes.
Regards
Edited by Enigma_M4Link to post
