Thank you for the quick reply, Labern!
To answer your question: Yes, these walls are all tapered. It's supposed to be a cookie cutter. So the thin edges are thought of as cutting edges.
Between the lines I read that my taper might be to steep? Is there a setting within Cura to adjust how tapered edges are to be treated, or should I adjust my model?
Thank you!
Edited by Kastenbrot
Labern 774
Hey. Welcome to the forum.
What you are seeing here is what it will actually print.
This is determined by your nozzle size and as those corners of the model are actually bigger in area then the straight lines then it will print them. Where as the straight lines are to thin at that point.
Are those thin walls tapered? Fatter at the bottom and get thinner as they go up?
Sorry I'm not able to view your file right now so can't check myself.
