UlrichC-DE 123
The BB core can also clog with PVA.
It is not very unusual for a core to clog. The deposits in the pressure nozzle turn into carbon over time.
(Ashes to ashes, dust to dust, filament to coal)
An acupuncture needle helps well. But generally , manual heating helps well .
If the blockage is higher than the pressure nozzle, a cleaning is difficult. Cold and hot blocked are then not feasible.
(Then I also use a brass rod M3 to press material.)
Although personally I would just buy a new core.
I think.
I give $100 and get two hours of free time and the problem solves itself. Or I work on it for one and two hours and afterwards I am not sure if it would have been better to buy a new one.
I'm not trashing the old Cores for this. One day I'll work on it 🙂
Jasonjason 6
Manually set the temperature hotter, and try another hot and cold pull.
you can manually set the temp on the touch screen somewhere.
someone may have put a hotter melt temp
material in it. What other materials have you been working with?
you can’t break it more.
also try poking up the nozzle with a .3 mm drill or pin.
have had to do this on wood filament before.
aliexpress sell needles just for this job the right size.
