Connect to octorpint via your webbrowser, upload the file via the printer (you are able to choose where the file will be uploaded, internal SD of printer or SD of Raspberry). Sometimes it fails, then try again!
What is the benefit of Cura uploading files to Octoprint? To use the Octoprint options you still have to make connection via Webbrowser!
gr5 2,189
@Aldo who wrote that plugin might have some ideas.
tiagomaricate 0
Hi @Aldo! Could you help me?
