1 hour ago, igniparra said:I've adjusted the bed with the paper pinching technique, and I think I got it right.
Not terribly reliable using paper. Far better is to get a set of feeler gauges and then set the nozzle to, say, 0.5mm above the build plate and then drive the nozzle around manually and use the feeler gauge to check the height in various places and adjust the height screws as appropriate. Very quick to do. I always print on blue tape so I just add 0.1mm to the height to account for the thickness of the tape.
igniparra 0
To illustrate... I want to be able to diagnose a print by looking at the artifacts, I'm not there yet, clearly 😛
