1 hour ago, SandervG said:Hi, could you share your Cura project too, so we can look at your full set of settings? Thanks!
Sure. I didn't have a .3mf file saved for this print, but I recreated it as best I could recall. We needed an extreme level of structural integrity in this component, so the wall count is abnormally high with 75% infill to bolster any compression loads the walls couldn't handle. Because I've had issues with oozing, I turned on coasting and increased retraction to 8mm. Otherwise it should be a stock 0.4mm Sprint profile.
Edited by TrueNorth
SandervG 1,521
