Thanks for the response. I'll give that a try. I "think" I have already tried the end gcode without the "M84" and got similar behavior. I'll report back later today.
Thanks again!
Bill
Thanks again!
Bill
Deleting the "M84" command has no effect on the reported problem. I'm not sure what to try next.
Bill
Try doing only a home, then an M84 gcode. After that are the steppers on? Can you move the print head? Or are the servos still on?
Slice with some other slicer that works for you - then look at the gcodes towards the end.
Here is an end gcode routine that works well in Slic3r and KISSlicer. I wonder if the problem is a firmware issue?
G92 E0; zero extruder
G91; incremental mode
G1 Z3 E-8 F5000; raise Z and reverse filament
G90; absolute mode
G28 ; home axes
M104 S0 ; turn off temperature
M140 S0
The above just doesn't seem to work with Cura. Disappointing.
Bill
What 'doesn't work with Cura' about it? Cura doesn't care either way, really. The end gcode is jsut text that gets appended to the file, and sent to the printer.
There's nothing non-standard about either version of the end gcode - they both do much the same thing, and using very standard Marlin gcodes. The only difference is that the one that 'works' doesn't explicitly turn the steppers off.
upload the gcode generated by cura gcode or your cura profile to check it
The CURA endcoade for Rostock machines needs to be improved. I have, on multiple occasions, ruined freshly printed parts by forgetting to change the endcode.
All you need is a G28 command - that will home the machine. I am running a RostockMAX and it works fine. Here is the endcode i use, i strip out anything that is not required to keep it simple.
M104 S0
M140 S0
G28
M84
This works fine, i do not get the motor creep' you speak of.
Hope this helps, would love to see CURA improved for the Rostock machines in the future.
DG
What firmware are you running? Some older versions of Repetier fw for Deltas could not handle Curas profile string at the end and this same behaviour occured. Try deleting that last line..
Thanks, gadgetfreak. Deleting the configuration string (the last line of the gcode) solved the problem.
I am now using Cura 14.01 for all slicing tasks and it is performing well. I really appreciate the efficiency of motion it produces (few-to-no unnecessary hotend movements).
I have successfully converted my Rostock MAX to a dual extruder configuration and Cura slices models such that they print very well.
It would be nice to have the option to "turn off" inclusion of the configuration line in the gcode. But, hey, if that's the only problems I have with Cura it's no big deal.
Next week I'll begin printing files using HIPS for support material. I hope things continue to work well.
Thank you, Daid, et al. This is a great slicer.
Bill
illuminarti 18
Do you need to simply remove the M84, so that the motors remain powered, and hence locked in place?
