16 hours ago, gr5 said:I can see by your screenshot that you have windows. It would be helpful if you posted the cura log file. I think if you do "help" "show configuration folder" it should show possibly 2 folders and one of them should have cura.log in it.
Anyway, as a workaround you can click the little arrow next to the button and save the gcode file to your harddrive instead and then drag it to the removable drive.
thanks. i'll do that.
gr5 2,204
