Carla_Birch 116
You can buy nozzles that fit the print core from a few places, the main problem is the risk of breaking the print core in doing so because it’s got a thin metal neck part that you could snap easy if you twist the heat block when taking the nozzle out.
the printer will still think it’s a 0.4mm nozzle so you will need to edit the line widths in Cura
UlrichC-DE 122
Nozzle swap, as on the UM2, is not possible. Because the swap corresponds to a conversion that can - but does not have to - succeed mechanically. In addition, the software can only be tricked out afterwards.
There is also a third-party manufacturer (3D-Solex) that sells cores with swap nozzles. But that is also only a compromise. (In any case, you can't save a cent this way)
Better you buy an appropriate core. I swap the printer cores almost daily (0.8,0.6,0.4,0.25) This is a feature of the printers. It is faster than screwing and therefore worth it.
