3 minutes ago, GregValiant said:Are you printing over the USB? If so then put the file on an SD card and print that way.
Essentially, there is only 1 layer (a really long one) with Spiralize so it shouldn't retract once it's above the base. You could try setting your line width to .6 to make the walls a bit stronger.
I'm already printing it with SD card. it's suppose to do that but for some reason every 1/3 of the spiral it briefly stop and continue again that's why it has that pimple effect. I might try that in the future thank you.
GregValiant 144
