Why is PLA behaving like this?
oskars
Posted · Why is PLA behaving like this?
Hello!
I'm troubleshooting this messy print quality...
Cura 4.7.1
Nozzle size 0.8
Layer height 0.25
Wall thickness 1.7
Infill 20%
Printing at 220 celcius and I have tried to go down in speed and even raising temperature with no success...
What would you say is the cause of this?
    I switched to a new TFM coupler before summer. Haven't printed since then I think.
    Nope. Haven't cleaned the nozzle. Might that be a cause? If it is not cleaned the extrusion wont be as good, and may result in this quality?
    Yes, I would give the nozzle a good cleaning before looking for other reasons. If the nozzle is partly clogged it can happen that you don't get a consistent extrusion.
    Another idea, have you tried a different filament spool?
    yeah... procede cleaning the nozzle as Smithy said... atomic method
    And them.. if this doesn't helps try another old version of Cura cause this 4.7.1 is not stable yet and it's ocorring some issues (blobs) in the outter shell.
    By the way I can see slightly underextrusion and blobs on the wall if I'm not wrong
