Figured it out.
Two things have to happen:
- an STL measuring X x Y x 3mm (for Z) has to be created and stored in the C:\Program Files\Ultimaker Cura 4.7\resources\meshes directory
- the printer definition json has to have a line added called "platform": "filename_of_stl" added in the metadata section.
Results:
Smithy 1,145
I don't think there is a forum post about that, but not sure.
The print bed in Cura is a kind of picture, which is located in the directory with the printer definitions. So when you look into the directory for your printer profile, there you should be able to find the picture or the configuration file where you can see the location.
This information is just our of my head, but take a look at the printer profiles, then you should find it.
