Have you tried not aborting the print manually and see what happens?
If I understand your description correctly it sounds like it is priming the print head, which can indeed take a couple of minutes and your print should start by itself with just a little bit more patience. The few strings of filament you should be able to easily clean up from the bottom of your build chamber at the end of your print.
SandervG 1,521
Hi @Xpect, thank you for your message.
Xpect 0
