Thanks Smithy.
I have tried with UM PLA Yellow, same thing.
But I am in the middle of a print, maybe the machine cannot print and look for filament at the same time.
Thanks Smithy.
Could be, I don't know, but just try it when you have finished your print job.
If the printer also cannot detect other spools then it must be something else.
I have tried again and finally got the spool to get recognized :)
Great, thanks for the feedback.
I guess there is faulty batch of UM PLA black, it is my only spool which could not be detected.
Smithy 1,145
I can give you just a generic hint, I have no material station, but it is basically ok that you cannot select UM PLA manually. But you have to know that when you select PLA manually then you have to select Generic PLA in Cura and not the UM PLA even if you loaded a UM spool. In fact it doesn't matter the profiles are the same, but you have to know that. Not a nice solution but a workaround if it is just with one UM spool.
And regarding auto detect of the NFC tag, have you tried another spool? I am asking because I also have one UM spool (also PLA back) which is not recognized by the printer. I guess there a problem with this nfc chip on the spool or maybe the batch of the spools have some problems. All other UM spools are working fine for me.
