10 minutes ago, ktsandhu said:In hindsight I was using ToughPLA on a UM2+ which I don't think is compatible perhaps for this reason?
Nah, I don't think that matters honestly. Unless there are reasons I am currently not aware of, you should be able to print ToughPla on an UM2+.
- 1
stu_le_brew 42
Some thing I learned of a long time ago was to pull up the white part of tube clip while pushing down the tube, I use a pair of tweezers to do this - it ensures the tube is securely fixed to the tube, then I put the blue clip under the white part
I have not had the tube come out on my UM2 for years
good luck
SandervG 1,521
Have you visually inspected the white collets that you stick the bowden tube into? It should have 4 small metal blades that pierce into the bowden tube and hold it in its place. It is possible that perhaps yours are bent, or perhaps not all 4 are present? I would get in touch with a local reseller and see if you can purchase a few of those white collets.
geert_2 558
Yes, I do it similarly: I push in the tube, then while I keep pushing on the tube, I lift the ring of the collet, and slide the horseshoe clip onto it. So it sits all the way down without any play. Never had tubes coming off.
To make this easier, I made a custom horseshoe clip, so it doesn't keep falling when I try to handle it:
It is old but still on my page (and then scroll down):
https://www.uantwerpen.be/nl/personeel/geert-keteleer/manuals/
ktsandhu 0
I've exchanged the unit now. I did purchase a maintenance kit in parallel with the machine, I had replaced both the bowden tube and collets which didn't help unfortunately.
