16 hours ago, nallath said:
Interesting read that highlights some of the complexity of the issue.
One thing I note as a Creality user, from what I've read there, I should have the problem too ( specifically on my ender-3 ), but I don't. The only thing I can attribute it to is I'm using the TH3D unified firmware, and running it on a 32 bit board. I also use a CR10s Pro V2, which is using the Creality stock 32 bit silent board and the default Creality supplied firmware, again not having the issue. Perhaps the issue relates to 8-bit boards and/or the firmware config ?
It would be interesting to see if someone can compare the two/three and see if the issue arises still. I threw out my old 8-bit stock ender board so I can't help beyond that sorry :(.
1
nallath 1,080
https://github.com/Ultimaker/Cura/issues/8321
