Cura not working on Fusion 360
Jim8163
Posted · Cura not working on Fusion 360
I've never had a problem designing parts on Fusion 360, clicking on "3d Print", selecting the part, clicking "Cura" as the print utility and hitting "OK". Cura then pops up and I slice it and save it on my Ultimaker SD for printing. Now Cura won't even pop up after selecting the part and clicking "OK" like it always did before. I've uninstalled Cura and reinstalled it twice with no luck. I even upgraded to 4.7.1. Any suggestions? Jim
    Does it work when Cura is already open? I am on the Mac and for it works only when Cura is open because Fusion is not allowed to start a new application.
    • 2 weeks later...
    Sorry about the delay in responding to your answer but no-it still does not work when Cura is open
    You need to integrate Cura manually as with each new major Cura version the place where it is installed is changing. Once you told Fusion where Cura was installed it will find this specific version. ... up to the next version :)
    Sure it did. I use it quite often and did it just a few minutes ago.
    It did for you-not for me. I was enjoying this hobby until the new Cura upgrade . I haven't been able to print since.
    Posted (edited) · Cura not working on Fusion 360
    Hi @Jim8163,
    as you did not tell us what kind of op system you use, Windows, Apple or perhaps Linux?
    This and the version of the one you're using.
    Could be a number of things preventing this to work.
    However, there might be one not so known..  Did you renew your Fusion 360?
    If not, -you would not be able to send any stl file to your printer -but you might still be able to make drawings..
    Thanks
    Torgeir
    Edited by Torgeir
    Text error.
    Sorry I didn't became an email from the forum.
    @Jim8163,
    that's correct, our systems are running quite good and this is why I gave you the hint in good faith.
    Anyway, please ignore my comment.
    Have a nice day,
    DD
        • 9 replies
