I've updated the printer and tried connecting it and it hasn't seemed to work. I do like the idea of printing remotely from my phone and doing it from the app. I am away from the station most of the time and off the network, so I like the idea of controlling everything from my phone.
You can access digital factory using webpage on your phone. I use both app and digital factory for UM3 as digital factory lacks features that the app has. It's a pain but I think the focus will be put more into digital factory and hopefully gain more features there for UM3.
With Digitial Factory, you have to be on the same network for it to work? Or is there a way that I can be away and off the network and remotely print something?
- 1 month later...
Carla_Birch 116
On 10/22/2020 at 2:47 AM, 3dprntz said:With Digitial Factory, you have to be on the same network for it to work? Or is there a way that I can be away and off the network and remotely print something?
You can set up to be cloud based now with the Digitial Factory, so you can check in on printers and manage them from any network. I personally check in via the web on my printers cameras when im at work to check they all printing fine.
This link will give you more info on how to setup and control: https://support.ultimaker.com/hc/en-us/sections/360003557920-Ultimaker-Digital-Factory
Smithy 1,144
The mobile app is old and wasn't updated the last 2 years. I don't know if there will be an update in the future, because the focus is on the Digital Factory which has got much more features than the app every had.
Why is the DF not an option for you?
