On 10/22/2020 at 3:51 AM, gr5 said:Possible but a huge pain in the neck to do it. You use the feature "per model settings". Basic steps:
1) Set the majority infill for your model (the infill that is more common). If it's half and half then pick either 20% or 40%.
2) Add a cube to the build plate. Select it by clicking. Click "per model settings" icon on left edge. It prompts for mesh type. You can use normal I think but definitely you can use "modify settings for infill of other models". Set the minority infill in the settings (e.g. 20% or 40$). Consider removing all other infill settings from the mesh type.
3) Using scale tool, make the height (z scaling) equal to half your layer height. Make the width and length (X,Y size) larger than your model.
4) Now multiply this part by the number of layers you want to have the minority infill.
5) Now select the "per model" parts one at a time. Select the move tool on the left side, set the Z value by typing in the height for the layer to use the minority infill. e.g. 0.7mm. Repeat for all "per model" cuboids.
If you have 50 layers this will take 25 "per model" cuboids. Yikes. It should work though. Once you get good at it you should be able to do this in just 4 seconds per layer. Not too bad if you have less than 100 layers to do.
Make sure to do "save" "project" repeatedly as that will save everything including your "per model" cuboids.
If you try to follow these instructions and get completely lost, google "cura per model settings" and there are great videos.
yikes, is there a better example of why we need an undo function in Cura.
I shudder at the thought of placing 50 of these without an undo function lol.
gr5 2,334
scheerjacob 0
Thanks so much @gr5!! I did think of that because I had seen a few per model settings videos on youtube and some of the things people came up with were totally insane. That makes sense, but indeed it would be a real pain to create 50 tiny layers and set each one to a different density.
My question is really for anyone with a coding or developing background who knows how to modify the code that's working behind the scenes. Where is the density variable implemented in the code and can it be adjusted on a layer by layer basis like the angle matrix? I tried to figure that out on my own, but I'm not good enough at coding to really figure out where the variables are implemented and how.
Any thoughts would be greatly appreciated.
