Okay, I am a bit ashamed. It turns out that my digital calipers are broken. I cannot reset it to zero anymore, causing all my measurements to be distorted and therefor the print being distorted and also me measuring the wrongly printed part with broken calipers. I just got out my analog calipers and apparently Cura is doing fine. Redesigned the part and now it prints in the correct ratio.
Once again, sorry..
- 1
- 1
gr5 2,192
what axis is the one that is the most problem? x,y, or z?
What is the expected size and measured size?
How far off is it?
Typically it's either off by a lot (2X) or a little (0.2mm).
