Thank you for your reply, gr5. I found the setting, checked the box, and sliced again. Unfortunately, I had the same result; the print head slides to the right until it reaches the stops, and keeps on trying to go in that direction until it gives up after about 30 seconds.
I can successfully print the files that came with the printer, so I know the printer is working. It's just the files I try to make with Cura that cause problems.
gr5 2,210
The center is NOT (0,0). The lower left corner is. The only printers that have 0,0 in the center are delta printers. Google what a delta printer is if you are not familiar. They have round build plates, not square or rectangular.
go to left side of screen in PREPARE mode. Click on your printer, then do "manage printers" then "machine settings"
There is a checkbox about 0,0. Change that and slice again.
