Hello gr5,
thank you for the detailed reply.
I lowered the nozzle a bit like you suggested and got better results. Still some gaps however depsite being really close and the top layer looks the same.
I suspected that I have an underextrusion issue as well.
To check that, I printed a hollow cube in vase mode. So there is only one wall which should be 0.4mm thick. At 101% flow rate, I got to almost exactly 0.4mm. The caliper is a factory calibrated Mitutoyo, so it should be precise.
Also, as you can see in the overview image, the nozzle impacts the already printed first layer (0.15mm) quite severly. So that should be an indication that too much material is deposited or the nozzle is to close.
The too point above indicate that it is not an underextrusion issue. Or do you think it still could be underextrusion despite that?
What I also do not get: If it is underextruision, why only in one direction?
The volume I am extruding is 3mm³/s, on the initial layer and top skin even 1,5mm³/s.
I uploaded a picture of the top layer and also the first layer after infill as well.
The top layer is actually printed with 110% flow rate.
I found it interesting that on the first layer after infill, what looks like 8 lines are actually only 4 (watched closely during printing). The start and endpoint of the bridges do not seem to be aligned somehow.
Printing Material is FormFutura PLA at 205°C.
Edited by gaduffl
gr5 2,004
90% of your issue on the bottom layer is what we call "underextrusion". If it occurs mostly on the first layer then it means you haven't levelled very well. Typically the bottom layer is 0.3mm thick (it's a cura setting - initial layer height) and it prints with the Z value at the same value (in this case 0.3) which means the nozzle is 0.3mm above the glass in this example. Except you are supposed to level things a bit tight so it's really only say 0.2mm above the glass so that you overextrude the bottom layer. If you don't overextrude the bottom layer and get some good squish going then the part will almost surely come loose by the end of the print.
So answer #1: leveling problem.
However you said you get underextrusion on other layers so you have a more serious underextrusion issue and maybe not a leveling problem. A typical printer maxes out at about 5-20 cubic mm per second. So keeping it below 5 should be easy for any printer. To calculate the number multiply your line width X layer height X print speed. Yikes Math! Don't panic. It's just 3 numbers you probably already know memorized. Line width is probably 0.4mm if you have a .4 nozzle and layer height is probably 0.1mm or 0.2mm and print speed you should know. So for example 0.4mm line width and 0.1mm line height and 40mm/sec multiplies out to 1.6mm^3/sec. Well under 5. So check that first.
Answer #2: underextrusion.
Regarding some lines being thicker and the line going the other way being thinner - it's probably a little bit of backlash/play as stated in the 3dverkstan guide. But it looks very minor in the above photos. Fix underextrusion first.
Answer #3: don't worry about backlash/play - the amount you have appears minor.
