Bricked S5, U-Boot screen at start up
manujoe
Posted (edited) · Bricked S5, U-Boot screen at start up
After the latest fimware upgrade, My S5, is bricked !
This screen appear just after power up :
B3F56E18-1582-466B-B40C-9BA3E93C8BDF.thu
Please let me know how to make my S5 alive again ?
  - Do you have a procedure to reinstall the kernel ?
Regards.
Emmanuel.
Edited by manujoe
    • manujoe changed the title to Bricked S5, U-Boot screen at start up
    Posted · Bricked S5, U-Boot screen at start up
    Contact your reseller. There is a procedure for restoring the firmware, but since it requires to remove the bottom cover there is a danger for touching high voltage components. Your reseller can help you and use the correct procedure to meet your countries regulations.
    • Thanks 1
    • 10 months later...
    Mine did the same thing and because it is out of warranty all I get from Ultimaker is "sorry about your luck"!  Mine will not recover with the SD card.  Ultimaker's position is no way the firmware did it.
    Facts:
    Worked fine pre-firmware update
    Froze during firmware update
    Only gives screen above when powered on
    Will not boot from SD card
