Contact your reseller. There is a procedure for restoring the firmware, but since it requires to remove the bottom cover there is a danger for touching high voltage components. Your reseller can help you and use the correct procedure to meet your countries regulations.
Mine did the same thing and because it is out of warranty all I get from Ultimaker is "sorry about your luck"! Mine will not recover with the SD card. Ultimaker's position is no way the firmware did it.
CarloK 204
Reddy2Print 3
Facts:
Worked fine pre-firmware update
Froze during firmware update
Only gives screen above when powered on
Will not boot from SD card
Navin2020 5
that is terrible?.. for such a costly item (shocked)
