tinkergnome 926
On 11/10/2020 at 2:56 PM, johnroy22222 said:Is there some ground rules which I failed to follow ?
Basically - make it manifold. It has to be a solid single object and watertight.
- no "floating" faces
- no overlapping faces
- no internal geometry
- no holes in the mesh
This model has all of it🙂 as far as i can see...
Whatever you did - it does not work this way.
There are step-files in the original design. I recommend to use these as the basis and make your modifications with a proper CAD program. FreeCAD could be used, or even Fusion360 if you want.
Some pictures:
The X-Ray-view in Cura gives a rough indication of all "problem zones" (marked in red).
3DBuilder imports it like this:
Meshmixer counts 88 separate shells that are not connected to each other
...and PrusaSlicer counts the errors in more detail for you:
Framar 38
Your model is probably wrong. I can try fixing the model using the STL but would be easier sith a STEP file.
Can you post your CAD file?
