How long does a factory reset usually take? I just did one to try to remedy a network issue and it's going on twenty minutes now with just "Ultimaker S3" on the screen.
@wfin73 You are hijacking a topic that has nothing to do with the original question. Please start a new topic for unrelated questions.
Short answer: a factory reset should take not much longer than a standard system boot, i.e. about 5 minutes. Power cycle your machine when it takes 20 minutes. Worst case you have to do a new factory reset.
A factory reset was mentioned in the thread, I simply asked how long it took, this is not hijacking by any means...
- 6 months later...
CarloK 204
This is on a UM3, isn't it?
The second print core is printing too close to the build plate.
There are a few things that can cause this and for now I see only two possible options:
1) Do a factory reset from the menu to clear all existing leveling data. It should work correct after this. Perhaps first note the XY offsets for your current print cores to avoid having to do the calibrations again. I always leave them at the default value as the results are good enough for me.
or 2) Do not use the automatic leveling. On the smaller bed size from the UM3 this is a nice gimmic, but manual leveling will give you just as good printing results and is slightly faster. On a larger printer like the S5 the automatic leveling is required to get good adhesion.
