Sure you have installed the latest updates? Including the drivers of the graphic-card?
If it was Cura that "bricks" the computer, there should me many more complaints about it! So start with telling us more about your computer...
Edited by MariSure you have installed the latest updates? Including the drivers of the graphic-card?
Edited by Mari
Computer |
1060 6gb Windforce - Nvidia Latest Driver
Ryzen 5 3600
Windows 10
32 gb Ram
Laptop |
750ti Nvidia
Intel i5 - non spec
Windows 10
16 gb Ram
Cura tested updates
1.8
1.7
1.3
Results: When launched, at completely random times. While in use, not in use and reset completely. There is a spike out of nowhere to cpu (non consistent) and then complete computer shut off. Safe Reboot and all.
Only Cura related. Other slicers have no issue and computers work as normal otherwise. The only guarantee is when cura has been launched and is in the background or in use.
There is an issue with Cura (and other applications!) running on some Ryzen systems. See these threads:
https://community.ultimaker.com/search/?q=ryzen
Also see this github thread, which has some suggestions but no definitive fix that works for everybody:
GregValiant 156
The Cura team will need more info.
What computer / processor / operating system, and the graphics card info if you can provide it.
Which version of Cura.
In Cura select "Help / Show Configuration Folder" and find the Cura.log file. Post that Log file here.
More information is better.
