Cura Slicing Error
simon
Posted · Cura Slicing Error
Hi Daid, I have been trying to slice this part, but Cura doesn't support the overhang properly in this instance.
IMG 0424
Capture
Also the brim is starting from the projected edge of the part.
Do you need to see the file or do you already know what is causing this?
Or is it something I have done?
Thanks
Simon
    I remembered seeing something alike, do not know wich cura version Simon is using?.
    I see a part of a 2 in the screenshots, so I guess a newer version.
    Reading, Daid wants to see images and examples...
    This is what I found, printing a 1:160 model train. Notice the brim in the front part.
    1st solid view
    Knipsel1312solid
    2nd An 'older' version 13.10
    this is what Simon wants to see, and you might suspect..
    Knipsel1310layers
    3rd Newest 13.12test. (13.11.2 gave same brim)
    Like Simon's screenprint..
    Knipsel1312layers   kopie
    All examples using same settings..
    Yes, I'm aware of the problem (combination of support and brim giving issues like this). I have not looked into the cause yet.
    Yep, latest version of cura. Interesting that 13.10 does it correctly. Can I use 13.10 with the latest firmware. Are there any health warning with 13.10. And lastly can I use both versions side by side on the same computer (PC)?
    I don't see any Health issues :) , give it a try and see what happens.
    Í have 5 versions installed at the moment, you might want to walk through the settings if you import settings from a gcode sliced in another version. And you miss some updates, but hard to tell what and which.
    Side-by-side installs are supported on Cura (with Windows&Linux, on Mac it can give weird issues) It was actually a design choice to support this I made very early on. I do not want to force people to only use the latest version. Which is why also all the old versions are available for download.
    You won't have the brim issue with 13.10 because 13.10 does not account for the support material with the brim.
