Hey thanks for the reply ahoeben!
Yes in the simplest form your suggestion should work, but it is a lot of work and added printing time. however due to the nature of the horizontal hole expansion basically working on every internal polygon of the part (which includes circles) I need to be able to select just the polygon to expand.
I have attached a picture to highlight what I mean. The attached is one piece and so in its current form the horizontal hole expansion will act on every polygon (marked with the white dots) because each complex shape is a polygon.
I still hope to be able to be selective in which polygon the expansion is applied to. This will overcome the inherent design floor in how these 3d printers work and why the holes are smaller in the first place.
ahoeben 1,111
This should already be possible using the Per Model Settings tool, see https://support.ultimaker.com/hc/en-us/articles/360012031399-How-to-adjust-print-settings-per-model-in-Ultimaker-Cura
Load an additional model and overlap it with the main model (or create a support blocker as a shortcut). Then select the Per Model Settings tool (the one above the Support Blocker tool), and set the added model (or the support blocker) to "Modify settings for overlaps". Set the option for "Cutting Mesh", and then add the Hole Horizontal Expansion setting and adjust its value. Caveat: you will get additional walls.
