Wow time just flew by lol
I actually had a chance to try that just last week. I tried some gcode from home at work and it resulted in the same thing.
I havent yet tried gcode from work on the printer at home though.
I am going to try lighter rolls of material on the machines at work too just to double check, since they both have fresh 3kg rolls on aftermarket roll holders. I don't expect this to change anything though since I used the same roll holder at home and havent had issues but I know there could be more friction somewhere.
My last ditch effort may be to buy new motherboards for the machines at work :/
geert_2 463
If you haven't done these already:
Maybe take a gcode file that goes well at home, and try that on the printers at work? And take a file that goes wrong at work, and try that at home? Then you know whether it is in the gcode or not?
Exchange spools of filament at home and at work, just for a testprint. Print both with the same gcode file. Then you know if it is in the filament?
I was thinking about worn-out white teflon couplers, but from what you said, I think you already replaced them, so that can't be the problem anymore? Idem for worn-out feeder wheels, clogged nozzles, etc.
