I can wholeheartedly recommend using OctoPrint. You can send a print directly to OctoPrint from Cura and monitor the print as if it were a local printer. You can install OctoPrint in the same computer that you use now, but if at all within your budget I would invest in a Raspberry Pi to install Cura on so your slicing computer does not have to be tied to the printer.
1
GregValiant 1,141
There is a lot of wordage on this but doesn't appear to be much help. There was some promise in this GITHUB thread (one of many) but I think it keeps getting deferred. @ahoeben might be the most knowledgeable on the subject.
JarenElectron 0
I may need a different software based on the looks of it. Cura is a good slicer, maybe I can find some monitoring software that I can just feed Gcode and get good results. Seems like developers are not too interested in helping with USB based prints. I personally find that it helps with automation when you have a heavy print load... Oh well than you!
