Amazing. Thank you @Torgeir.
Where did you find a copy of the BoM for the UM3, this would really help me out in the future...
Cheers, Rich
Cheers, Rich
Sure, here it is;
https://github.com/Ultimaker/Ultimaker3/blob/master/BOM/BOM Ultimaker 3.pdf
You'll also find complete drawings etc. in the other directories..
Cheers,
Torgeir
Torgeir 248
Hi Rich,
According to the BOM for UM3, the name of this unit is; "Grip axis" and P/N is; 1960-1.
Best place to find this item is your UM dealer in your country, I'll think.
If there is starting to be "much" play between this shaft and the (plastic) gear wheel you may consider changing this gear wheel as well.
Good luck.
Thanks
Torgeir
Edited by TorgeirAdded text.
