GregValiant 1,304
You are now officially on your way.
I always use a skirt. Yes, it gets the plastic flowing, but it also gives me a chance to see how my bed leveling went. If it too thin or thick I can make a quick adjustment on-the-fly. Like many things about 3d printing, it takes practice.
Kamakanaaa 4
There is a plugin called Z-Offset Setting. It adds the ability to manually change the z-offset which should help with your issue. Another thing to check is your bed leveling with a sheet of paper. A regular size copy paper should have little friction when moved between the nozzle and bed.
GregValiant 1,304
You need to level your bed. Along with insuring that the first layer is uniform thickness across the whole surface, it insures that no point of the bed is above zero.
Cura never generates a Z value less than the Initial Layer Height and that is always a positive number. Cura has no idea where your build surface is. It's up to you (or your Auto-Level system) to make sure it is at or just below zero. There are a lot of videos that cover leveling for printers like yours.
johnboyman 0
Thank you. I have got that down finally.
