GregValiant 1,488
It says it will take 2.5 hours to print. That is more than 1 layer. It might just be a preview problem. When you generate a gcode - how big is the file? If you open the gcode file in Notepad and search for "Layer" it should start at layer:0 and continue to the top layer.
TiseHe2 0
If you have in idea how I can solve that that will help a lot.
