GregValiant 1,321
All the layers are in the gcode and the gcode finishes up correctly. We'll see what Torgier comes up with looking at the 3mf.
I'm going to assume you are printing via the SD card. The problem you are seeing can happen when an SD card gets corrupted. You copy a gcode file to the card but some of it lands in a corrupt sector. Re-formatting a card usually sorts this out. If you are printing via USB there are other things that can happen to stop a print.
1
Torgeir 248
Hi @TrollingFlies,
It will be a lot easier for us to analysis if you share a copy of the project file that's holding all info about your cura setting for this print.
Thanks
Torgeir
TrollingFlies 1
2 color spinner.3mf
