Be sure you're using the very latest Cura - version 13.12 was released just a couple of days ago, and there are a bunch of changes being made at the moment regarding how retraction and non-printing moves work, so that might help fix your issues.
Travel speed should be set to 200mm/s or higher. That will help break the threads of plastic when moving between parts of the print, and minimize oozing of the head during the moves between parts of the print. Small amounts of oozed plastic can then catch on the finished surface when the head moves from one part of the print to the other. In the advanced settings, i recommend setting the minimum travel to a small amount, like 1.5mm, turning off 'enable combing' and setting the minimal extrusion amount to 0. That will ensure that you get retraction on all moves except the very shortest ones.
You should also consider increasing the acceleration settings for your z-axis, as discussed http://www.extrudable.me/2013/04/02/the-myth-of-z-speed/, to minimise the time taken for changing layers.
13.12 also includes a new firmware that should get retraction working better to avoid the blobbing on surfaces. Once you have that running, set your retraction to 4.5mm at 30mm/s (you may need to increase your maxZ speed setting to allow that).
gr5 1,968
Overhangs are difficult - the areas with the worst quality are on the underside of areas that have no support. I don't think you can do much about these except possibly slice thinner layers but layers thinner than .1 sometimes looks worse than .1 so I'm not sure if this will help. If you want "perfect" surfaces, then better to design zero overhangs if possible or make the overhang surfaces hidden (like the toothbrush holder).
The basket looks perfect to me. If there is a problem you will have to highlight it.
The other small bumps and holes - I'm not sure what those are. Maybe someone else knows. Probably a slicing issue. Possibly you can make those better at slower speeds e.g. 25mm/sec. Maybe not.
What was your shell thickness? Perhaps a thicker shell will help. .4mm is not thick enough if you want a nice surface because if only .4mm shell you will sometimes see support structure coming through the side. Always set this to a multiple of .4mm (e.g. .8mm 1.2mm 1.6mm).
