On 1/11/2021 at 11:49 PM, gr5 said:You have a few features to enable/disable here to improve the view. First of all you should zoom in (scroll wheel) and pan (hold down shift key, right click drag).
across the top of the screen look for "color scheme". First try "filament". I think that's what you have it set on in the lower photo. You can change the filament color by loading different colors in the PREPARE screen and reslicing.
Then in "color scheme" try "line type". I know you don't like that but it's very useful. Yes the outer layer is red and very dark. You can scroll through all the layers - the vertical scroll shows you each layer so you can check out if the infill is correct and look for issues with overhangs (I don't think you need any support with this model - except possibly the chin? The shoulders look like they will be fine without support).
I understand about visualization. The problem is that I am not able to define in color scheme: type the colors that I like. Everything just turns yellow. Supports, filling ...
gr5 2,333
ahoeben 2,047
"Compatibility mode" is limited to what it can do. If compatibility mode could do everything, it would be the only mode.
