Posted · Cancel to print one of the objects during multiplied printing possibility
When I'm trying to print quantity of the objects (in my case multiplied), during printing, especially during first layer job, some plastic didn't stick properly to the printing plate.
Obviously that could be happen in many situations so it's nothing what would worry me however in some cases I have to abort print and restart the job from fresh.
I wonder, if there is any possibility to tell printer to cancel print one of the objects during job so bad prints could not be continued where other will go until finished?
    This feature actually exists in Marlin for printers that use newer versions of Marlin.  Ultimaker split from the Marlin branch a while ago but other printers have this feature.
    It looks like you have an S5 so, for the S5 this is a definite "no".
    For the feature to work you have to insert certain comments in with the gcode so the printer knows which part is being printed next so it can skip over one or more of these.  I have been told that the necessary comments are indeed inserted into the gcode.  So for many printers the answer is "yes".
    • 2 weeks later...
