HI, thank you for your feedback! please see attached the file.
actually I have to print this file in ABS, 0.25 mm nozzle, to the best resolution I am able, to be within 2% deviation from STL file and solid infill.
I was thinking to use Ultimaker breakaway material as support, but I cannot block the supports generated inside the part legs.
would be great to have some suggestions from you related to this project.
kind regards,
Marius
kmanstudios 1,120
Cannot tell much without the file or .3mf file to evaluate.
