1 hour ago, nallath said:Do you have some images that show the difference? I'm not a 100% what behavior you mean.
Hi, I have made a small video where you can see that the speed of which the simulated extruder moves is very uneven. The link between the gcode and the robot is the program robodk which also makes a visual representation of how the robot will move. It shows the same uneven movements as in CURA.
Does this make sense or do you need any other information?
nallath 1,118
