GregValiant 203
They aren't there to support that radius feature because it is more than 55°. My guess (since they are rectangular) is that they are attempting to support the rectangle above. Moving the support blocker up higher might help.
Thank you for your replies, but:
- I need to support everywhere because there his a horizontal cylinder hole higher in the object and it needs internal support.
- How can the "unwanted" support support something that it does not touch???
- I tried to use the support blocker, but it is very hard to use because it works indirectly instead of simply clicking on the support that you would like to delete.
The only way I found was to set the angle to 75°, but I wonder whether the cylinder hole will be printed correctly, and it is only at the end of a long print that I will figure out...
@Flying_Roger, a little bit to late, but maybe helpful. There is a setting that forces this problem sometimes for some of my models: Support ->Use Towers
If this is activated try with uncheck it for this model.
fvrmr 11
Do you need everywhere support? Because you can change support placement to touching buildplate. With the option everywhere it will also print support on the model.
