4 hours ago, gr5 said:Strange. Your stl and gcode aren't helpful. Instead post the project file. Do "file" "save...". Then post that here.
Make sure "enable retraction" is checked.
Make sure "maximum retraction count" is 10 or greater and "minimum extrusion distance window" is less than 5.
Make sure "retraction minimum travel" is less than 5mm.
Check "max comb distance with no retract". Not sure if the latest cura has this setting only the burtoogle versions.
"Combing mode" is not on "off"?
Every option you said was already good but the problem still persist, this happen with all my prints
gr5 1,557
