Cura gcode example.gcoderetraction calibration test.gcode
Hi Smithy, thanks for your suggestion. Please see the gcode generated by http://retractioncalibration.com/ and the random example from Cura. They begin quite differently. Do I just copy paste the header from the Cura example gcode and change the numbers so it works with the retraction test? There's info in the header such as:
;EXTRUDER_TRAIN.1.MATERIAL.VOLUME_USED:851
;PRINT.TIME:2189
;PRINT.SIZE.MIN.X:9
;PRINT.SIZE.MIN.Y:6
;PRINT.SIZE.MIN.Z:0.27
;PRINT.SIZE.MAX.X:213
;PRINT.SIZE.MAX.Y:207
;PRINT.SIZE.MAX.Z:35.97
Do I need to find all this information in the retraction gcode and translate it into the header for this to work?
Not everything is needed, there are also some comments which are not needed. I am not an expert what is needed, so maybe someone else can give detailed advices.
But another idea. Have you tried to load the gcode in Cura and print from there or save it again? I think Cura adds the missing and needed header lines.
Here you have detailed information about the header:
Smithy 1,145
Check the gcode and compare it. I guess the header of an original Cura generated gcode is missing.
