Thanks IRobertI
I think that will be my only option, only issue is I believe that the nozzle temperature begins to drop as soon as you pause the print.
Will have to be a pretty speedy change over!
fingers crossed that this feature can be added via a firmware update in the future.
Seems crazy that this feature wasn’t dropped on this model.
IRobertI 474
Pause print, lift lever on feeder, pull old filament out, push new filament in (with a bit of extra push to properly prime), close lever and un-pause?
