The skirt setting helps in this case. This will print an outline before the first layer. This sort of "primes" your extruder. Also, lowering the temperature will help, as there less filament as dripped out of your extruder tip.
You might want to give SkeinPyPy a shot:
https://github.com/daid/SkeinPyPy/wiki
it's easier to configure then Skeinforge. And has the skirt enabled by default on 1 line, and can print multiple lines to prime your extruder even better. (feature not found in Skeinforge)
IRobertI 516
Before the print starts plastic can flow out of the nozzle and thus emptying it out. As your print starts the extrusion gear starts turning and starts filling up the nozzle again, once it's full it will start extruding properly. To help avoid this problem you can either manually turn the extruder gear a bit by hand just before the print starts to make sure the nozzle is "loaded". Or, you can be a bit more elegant and add G-Code to the header to make the printer do a bit of "pre extrusion" for you automatically. Unfortunately I can't give you any code right now as I'm not at my print computer but I'm sure someone else will come along and help you out soon enough.
