Wow, I myself had already canceled some print jobs. So far, the described by you I have not yet happened. I also use Cura 13:12 just like you. The software bug might destroy the machine. I've played very often in the Device menu during the build platform went down after an aborted job.
Madness, the Z-axis has very much power ...
In my UM2 a fan mounting plate was not correctly formed and already led to the collision with printed objects.
The machine requires mandatory collision sensors, this I have already mentioned in an email to Sander. So far, but still no answer came.
I may seem petty, but the power switch is behind the machine has no front reset button. And as soon as I have no money for a new machine together.
Thank you for your warning video.
illuminarti 18
Yes, I've heard about it from some one else on here in the last few days - but I don't remember who. But so long as that wasn't you on another thread, then yes, at least one other person has seen this :-)
The work around is trivial, of course - don't do that :-) - but I imagine it will soon get fixed in another release as there are some other probably-related bugs that need fixing too.
