I've attached the project file (a .3mf file correct?) to this post, and I have the Line Width set to .2 mm and there's still a hole.
Edited by DevExit
Edited by DevExit
So I got your part to slice with .4mm line widths by setting "horizontal expansion" to just 0.1mm. That will make your part .1mm thicker all around but I'm guessing that's okay? .05 worked as well but .1mm was better.
I'm more worried about the top/tip of your part now. That's not going to print well.
I'd print the part horizontally to get a nice tip but I have a printer that can use dissolvable support (PVA) and I assume you don't since the Ender 3 only has one extruder.
Not only is it not printing the last few mm of the tip, even the parts it *does* print are going to look like crap because there is no time for the filament to cool so you are just gong to get a big blob for the last cm or so. I have no solutions here other than printing sideways but then you need support which will look kind of lousy on the side with the support - but I think that's your best option.
That makes sense, I was hoping I wouldn't have to print sideways but yeah.
I'll try that and report back to you on how that goes, I'm just new so I'm not particularly sure how many supports I should put and wear so the whole thing prints properly but I guess trial and error are my friends, luckily it's a small build.
gr5 2,210
Please post the project file. Do "file" "save...". This file will contain your STL and your machine settings, the profile you chose the overrides, how you place the model and lots more.
Try setting "line width" to 0.2mm just as a test to see what happens. I'd try it right now but want to see you whole profile.
